throttle body bypass
hi guys i want to bypass the water pipes to te throttlebodies i can see the pipes in question behind the plenum chamber can this be done without removing the plenum chamber thanks guys:bow:
i did this on my tt, the first time you remove the plenum is a dog of a job as no matter how free you think the plenum is there is always a little rubber hose still on there somewhere, if you take them plenum of you'll see the small diameter pipe work running underneath these eventually go to the turbochargers, any scale forming over the years will reduce flow, increasing velocity hence reducing the efficiency of the cooling system. Once you have done the bypass its far far easier to remove the plenum for future maintenance and you can be assured of flow to the turbos.
if the engine is coming out then i'd definitely do it, and you may as well rip the egr out aswell whilst your at it.
