protoj · 14 hours ago 14 hr
i have done a diagnostic test on my autobox and it says that the throttle sensor circuit is shorted or disconnected, does anyone know how to solve this i am no mechanic by any means and any pictures where to find it would be extremely helpful thanks all.is there anywhere that i could take it to be fixed easily (and cheaply) thankyou
