protoj ·
Ive got a 92 tt auto ive started to fit a set of dump valves, and ive noticed the oil cooler is quite small.
My question is, does the oil cooler cool the oil for the engine and gearbox or just the engine is it worth upgrading to a 10 or 11 row oil cooler.
And my last question is, can i just remove the standard oil cooler and replace it with the new one and use the same rubber pipes.
Cheers me deers.
