How would you know if you had aftermarket injectors?
hi doc
i am no expert but, they are colour coded. i have venom 555's which are pink:shock:
dont know the colour of stock, 370's.
u can search the web and look at pics of different sized injectors.
al:cool:
First thing I'd do is open the ECU to see if there's a socketed chip. If there is, I'd take a copy of it and load the image up in one of the many free tools available (such as TunerPro) and compare the fuel TP scale between a standard BIN and your one.
(I do appreciate however, that not every one has an EEPROM reader/burner to hand!)
Regards
Simon.
Edited by WillyEd
You cant rely on the connector colour. For example a set of Nismo 555's have purple connectors, but so do new stock 370cc connectors.
If they are brown then its a pretty good indicator of original stock 370cc injectors though.
the reason i ask is my car has a Ebc so proberly have been chiped and if this is the case then i would just like to know whats been done woulnt you? And where do i look for these injectors any idea peeps
