twin turbo boost gauge
Hello folks how are use doing?
I was wondering, for the twin turbo do you need two boost gauges fitted?
cheers folks:D!
The answer is no. If it was yes then there would be two stock boost gauges.
i thaught this also.
you dont need 2 gauges (somehow)
however there are 2 turbos, technically you could have a dawes device (boost controller) set on 18 PSI,
and the other left stock.
the boost gauge would give a reading, but surely this is not correct?
if you have the 2 turbos on equal boost then i can see its fine.
Each turbo is equalled out by the balance bar on the plenum, and its the balance bar where the boost guage takes it reading.
The turbo's vacume pipes are linked via the Balance bar on the back of the engine, therefore (unless a solenoid is stuck) both turbos are working together at all times. Hence why theres only one boost guage, theres only one vacume system
DOH, beaten by 1 minute!
zogg, see the front bumper you have, i have the same and was wondering, is it easy to fit other bumpers to it, such as the one that seperates the front lights from the side lights?
