I have an oil temp / pressure gauge, boost gauge and water temp gauge, do I require any other parts to be able to fit these?
I already have a boost gauge in the car, is it just a matter of swapping them over?
Thanks guys.
you'll need all the senders and wiring / tubing to go between them if you don't already have them?
oil and water temp will be electrical senders, you'll need a T piece for the water pipe from the rad, you can get a sandwich plate to go between the oil filter and engine to get the pressure reading, i think you can get these with temp senders on too ? The boost pipe should just swap straight over..
Edited by crotchrocket
