October 16, 200818 yr hi guys i want to do a brake conversion to my rear brakes ie bigger one could anyone recomend a conversion that i could do with her many thanks :D
October 16, 200818 yr What do you have on the front...or what do you intend to fit on the front ? You need to match them.
October 16, 200818 yr So will the front calipers fit the rear std discs or would they have to be bigger.
October 16, 200818 yr Author What do you have on the front...or what do you intend to fit on the front ? You need to match them. the front brakes are skyline r34 mate, the front calipers will not fit on the back the holes are haly an hole out each:bow:
October 16, 200818 yr the front brakes are skyline r34 mate, the front calipers will not fit on the back the holes are haly an hole out each:bow: What I mean is that you need to upgrade sizes in proportion, to ensure correct brake balance. So, If you have GTR front brakes, then you want GTR Rear brakes on the back of yours, they are a straight fit.
October 17, 200818 yr Author What I mean is that you need to upgrade sizes in proportion, to ensure correct brake balance. So, If you have GTR front brakes, then you want GTR Rear brakes on the back of yours, they are a straight fit. are they bigger than standard 300 brakes mate and thank you for your help :)
October 17, 200818 yr are they bigger than standard 300 brakes mate and thank you for your help :) Yep, they are bigger.
October 17, 200818 yr Author Yep, they are bigger. thank you mate the search is now on for these brakes:D
October 17, 200818 yr thank you mate the search is now on for these brakes:D R34 GTR version will be harder to find, but the R33 GTR rear brakes are the same as the R34 and easier to find.
