Blitz SBC i-D Data Harness Connections?
http://www.blitz-na.com/Blitz_SBC_ID.htm
This was mentioned in another post but I am going to be wiring mine up in the next week or so and have been trying to decide what to monitor.
I've got the optional harness and Power Meter which allows me to connect it to 3 DATA inputs from the car. The inputs can accept 0 - 16v I believe and it states it can read TPS, water temperature, oil pressure, injector pulse, A/F etc
What would be usefull readings to view on a Z?
The display can be changed to temp/voltage/pressure etc I believe and can plot a graph/current/peak readings from the data.
I was thinking of water temp as one because i don't have anything other than the stock gauge. How is this calibrated though so the meter knows the temp from a given voltage?
The det sensor has been mentioned as a possibility.
What about injectors or air flow? Is this usefull?
Anyone set one of these things up like this?
[This message has been edited by ChrisC (edited 17-09-2002).]
chris just set it up for wat ya havnt got already
injector pulse and a/f and tps is wat id go for?
get the mech gauges for the rest
TPS would deffinatly be cool, if you have the boost controller right nextdoor like macca's, you could see throttle and boost, could see your lag on screen biggrin.gif
