Prop shaft
Got to replace the prop shaft bearing, is there any thing else that i should change ,to do with the prop at the same time hope this makes sence
Gearbox rear mount. Its usually the cause for propshaft bearing failure.
It sags overtime and affects the propshaft angle, which puts strain on the bearing. Nismo do an improved version.
