i've replaced the top rad pipe on my tt, now obviously i've lost at least a pipes worth of coolant. so i need to top it up.
this is something i've not done for years and not ever on the zed,
do i just poor some in the radiator cap(well the hole left after taking the cap off obviously)?
how do i know when i've got enough?
how do i turn the air in the new top pipe into water or will it do it itself?
do i need to run the engine to move it round and then add more?
do i need to unscrew the plug on the top of other end of the rad
what happens if i overfill it? does itpiss on the floor, go into an overflow tank or blow up?
damn i sound new or blonde or both
[sIGPIC][/sIGPIC]
yeah take off the bleed screw (other end of rad)...pour coolant into rad cap end of the rad whilst running the engine at same time....once up to temp might get a few burps etc...keep it topped up until stable...bung screw back in and cap on...check level for a couple of days etc
good lesson i learned was to jack up front off car force those air locks out with heaters on full works everytime.
dan.:)
i need to put heaters on? as in hot air vents in car or hot air gun pointed at radiator?
[sIGPIC][/sIGPIC]
put heaters on full inside the car... tbh, I'd drain, flush and re-fill the coolant - for all you know it's been in there years... having seen the state of some of the coolant pipes on my old car (in particular the 2 short pipes off the front of the engine) old coolant can allow a massive amount of corrosion to occur...
Even better, remove the radiator and fluch that properly - you'll be amazed how silted up it is!!
