Dimmer problem and indiglo's wont light up?
after fitting my new aftermarket gauges my indiglow lights wont work on the dash and my aircon lights/clock wont dim?
What have i done now :(
I also did that when i fitted mine.
Turned out to be the 10amp fuse. top row 3rd from the left
woohooo so thats prob it :D
ok il check it out 2mow.
Would anything else not work?
It cut out my rear lights, front side light. Then when i put normal beam on hi beam would also come on.
I checked the fuses twice and found nothing. checked all the inline and under bonnet fuses. and thought i buggered a loom. booked it in to the auto eletrition. Then thought i would have one more look and there it was :bow:
Just fitted mine recently and tried changing the speedo convertor and balls'd it up, gotta strip it apart now and re do it as iv been told i did it wrong the first time
Bloody Zeds
Fas
woohooo it was the fuse , cheers car.mad :D i was pulling my hair out a bit :(
You fixed it at this time :rofl:
Yeeeeeeep i wanted to take a pic of my new gauge set up at night and i just got in from work.
was well annoyed when the indiglows wouldnt light up grrrr
I know what you mean. its like OOOOSSSSHHHHHH1111111111TTTTTTTT
