tension rod
Hi all,
Been getting the car going again after along time garaged, when braking the car starts to shake really bad, I have uprated tension rods so it cannot be the tension rod bushes :confused:
Would it warped discs?
Yep the most likely culprit will be a distorted disc, though some of the other suspension components could be worn and causing it.
I would say the discs are more likely
If the car has been off the road for a long time, the discs would have corroded and this would cause juddering. This should clean off after a good run and should be OK. I would also check your steering rack track rods as they also get play in the nylon bushes and can cause the wheels to shimmer which also feels like a judder.
