The sender is the same type as the aftermarket oil pressure ones you get with the auto gauges.
Can i T and plumb this in just after the fuel filter or just after the fpr? and what do you suppose i should use to connect the 1/8 thread to the fuel flow? seems a bit odd!!!
Going to fit an eletronic fuel press gauge 2mow.
Thanks in advance.
