Fuel pressure gauge fitting help?
Going to fit an eletronic fuel press gauge 2mow.
The sender is the same type as the aftermarket oil pressure ones you get with the auto gauges.
Can i T and plumb this in just after the fuel filter or just after the fpr? and what do you suppose i should use to connect the 1/8 thread to the fuel flow? seems a bit odd!!!
Thanks in advance.
No posts to show
