ICE Amp Recommendations (Maybe some custom for you BOB)
Question: What go's 'snap, crackle, pop!'
Answer: My Phoenix Gold 4 Channel Amp on the way to work this morning!!!!
I think I've fried it! Anyway it's an excuse for an upgrade!!!!
Does anyone have any recommendations for a replacement Amp, I listen to a lot of NIN and Spineshank type music (NU Metal Type stuff) I'm looking for something to provide plenty of Quality, response and power.
Has anyone any recommendations??? or even old kit there selling, Bob, I'm sure we may be able to do some business on an Amp.
Mike
2 ch or 4 ch? what kind of speakers are you driving with it? and how many? budget?
Another good place to look is www.talkaudio.co.uk, in the classifieds, some good bargains to be had.
Group buy Mike?
I need two aswell. Possibly a 4 channel jobby to power two sets of Rockford Fosgates in the rear and a 2 channel for a set of Rockford 6x9's for the doors.
Can you get me the Rockford 6x9's aswell Bob???
Not hijacking your thread Mike but if we order at the same time maybe the Bob man might smile favourably on us and knock some wonga off! wink.gif
I was thinking about Sony X-Plod amps.
"If toast always lands butter-side down, and cats always land
on their feet, what happens if you strap toast on the back of
a cat and drop it?"
Steven Wright.
I'm up for a group buy, I'm driving some Infinity Kappa Componets in the front and 2 JL 8" Subs in the back, so the current setup is 4 channel. I may want to add 2 fullrange speakers in the back in the future in order to provide more mid range, I'm not sure I could do this without buying a second amp though.
Mike
Okey Kokey, let's see what the main man says.
I don't need an amp to drive subs as I'm using my Vibe Enclosure which drives itself! Nice bit of kit aswell.
I'm intrigued by these 1 Farad Capacitors aswell, they look the Rotts Rocks with the LED readout. Thinking about split charging aswell.
a cat and drop it?"
Steven Wright.
split charging is good if you play your system for long periods of time without the engine running, but if this isn't the case, it's often just as beneficial to change the battery for a deep cycle or bigger version (if possible), and also upgrade the engine bay wiring (mainly the power from alternator to battery, and all earth's)
That is unless you have a huuuuuge demand on your battery (and I mean huuuuuge, I was running 3 amps rated at 60a each off a standard battery and had no problems at all.)
Just checked me fuses, yep, blow the 20Amp fuse, I'll have to replace it and see if it everything still works.
Mike
Mike, while you're at it, check that no bare wires (power/earth/remote) are touching causing a short circuit.
Just replaced the fuse, not tried it yet, but there is a *slight* amount of bare wire showing on the +Power cable.
Mike
Yay, it works! and I have the hearing damage to prove it!
Mike
Did you insulate any bare wires too? they don't have to be touching each other, as the amp casing (AFAIK) is metal, it could short on that.
[This message has been edited by AndyD (edited 13-09-2002).]
With "Nu Metal" all amps will sound the same !!
As Ozzy Osbourne said "it's got no melody !!!" "sounds like they'ye being tortured FFS !!"
I listen to most Metal appart from Limp Bizkit stuff, I would liten to the 'RnB' or 'Rap' shite but I have taste biggrin.gif
Mike
No, it goesupto 26 but my head starts to hurt !
Mike
just let me know what bits you need guys and i will do the best i can, got some nice pieces coming in from the US soon so will keep you posted.
