Less Sharp
My N/A is less responsive when it's warmed up. Could this be the timing ? I have checked TPS voltage and its reading 0.43V .Also it's an auto and its sometimes reluctant to kick down when its hot, but all gears are there and changes are really smooth.Any ideas please guys. :bow:
TPS needs to be 0.45! Also better to be between 0.45 and 0.5 mine is at 0.46 ficking to 0.47 as you can never seem to get 0.47 without is going to 0.48!!
ย
Possibly need to adjust your timing as well and do this with a Strobe? Use the No.1 Cylinder for the timing light clamp though as the pulse from the CAS wiring loom seems to give a false read to the light! Compare with Conzult for best accuracy!
Kickdown could be gearbox oil...When was it last changed? Might be worth some new fluids in that? I have a manual so not the best to advise but i've read it on here a few times!
