Do i need to?
I undid mine once, but cant remember if it was when I took the engine out or took the sump off with the engine still in, hmmmmmm......
you took your engine out, are you a mechanic and if not did you do on your own , how did you find it?
Im not a car mechanic, but im a mechanical engineer. So worked on plenty of mechincal machines etc...
I found it fine. But there is a lot of cables, pipes so make sure you label them good. Top two gearbox bolts are a bit awkward to get at. Apartm from that, being my first engine I took out it was fine.
