Exhaust gas temp gauge/intake charge air gauge
Ok Im doing some research on fitting:
1. Air/fuel gauge
Am i correct in thinking that all i have to do to fit this is to wire in the gauge to the RHS & LHS o2 sensor ecu wires and jobs a gooden?
2. intake charge temp
Ive looked around ebay and a few other sources for a intake charge gauge with no luck :( Anyone have one of these fitted and knows where to buy one from?
Do both banks need to be probed or just one side?
3. exhaust gas temp
Found the gauge i want BUT where do i fit the sensor? nearest to the manifolds i would have thought!! and as above do both sides need to be probed?
Thank in advnace guys :D
Ahhhhhhh
I dont know which to buy.
Fuel pressure gauge
oil temp gauge
air intake gauge
exhaust gas gauge
air fuel gauge
i want them all
air fuel usually comes with its own sender but if you can wire splice it onto an o2sensor and the jobs a goodun cool
They work out much cheaper if you buy a gauge and not the sensor.
Was just wondering, i have my water temp and oil pressure sensor earth on the plenum is that a good earth point or not?
I'm not sure that the O2 sensors would give a linear enough signal for a %age gauge. They are intended to give out what is basically a binary signal, eg on or off ! Somewhere in the online manual I think there is a nice graph of the output.
But the gauge advert says it connects directly to your narrow oxygen sensor in your car.
Is this incorrect then?
What will i need to fit an air/fuel gauge then?
Well if that's what it says, then give it a go. Make sure you use the right wires as one of them will be the 12v (probably) heater.
