protoj · 12 hours ago 12 hr
just noticed that my car doesnt seem to be locking when i press the fob for the alarm, the keys have never been used to lock it since iv had it(just over 2 years) so i cant use them as they wont turn lol. it does lock if i push the button inside so the mechanism is working what could be causing it tostop working off the fob?
