wiper/aircon pod no power
happened twice now always seems to be when its bloody raining lol loose all power to the aircon/wiper pod also loose power to the interior lights when it happens always comes back on eventually any ideas what could be causing it stripped it off and couldnt see anythin.
cheers
only when it rains? could dampness have any affect? would imagine would only affect the connections unless there is a loose wire.
ย
Do all these run off the same fuse in the fuse box? might be worth a look.
Water has effected the back of the fuse box in the drivers side footwell, there is a relay that powers up a section of the fuse board when you turn the key to position 1, either the relay is faulty or the interconnecting bus bars are corroded ( most likely ) bit of a ball ache to remove and check out but you may have to change it for another one.
ย
Rob
  • 5 months later...
I need to check mine also, but it looks very difficult to remove, I dont want to damage the wires....
Is there any easy or std way to remove it???
eg removing the connectors first etc.
