August 29, 200818 yr Hi, Can anyone tell me if there is a difference between an NA and TT gearbox and if so what - does it have an adapter plate etc? Cheers,
August 29, 200818 yr The difference is in the bellhousing thickness. Fitment is the same. You can still use a TT clutch and flywheel, but you have to space the starter with some thick washers.
August 29, 200818 yr Author The difference is in the bellhousing thickness. Fitment is the same. You can still use a TT clutch and flywheel, but you have to space the starter with some thick washers. Cheers, would there be a quick way to tell, it looks like theres some wear on the flywheel from the starter motor? Thanks again!
August 29, 200818 yr Cheers, would there be a quick way to tell, it looks like theres some wear on the flywheel from the starter motor? Thanks again! No quick way, not without measuring bell housing thickness...and then comparing with another. If it was an NA box without the starter spaced out then it would'nt disgengage the starter motor after starting the car. Would probbaly sound pretty nasty too when starting and running with the starter constantly fighting with the ring gear. I forgot to mention...the flywheel will also rub on the bellhousing - unless you file down part of the bellhousing...or you let the flywheel do that for you which would'nt take long.
August 29, 200818 yr Author No quick way, not without measuring bell housing thickness...and then comparing with another. If it was an NA box without the starter spaced out then it would'nt disgengage the starter motor after starting the car. Would probbaly sound pretty nasty too when starting and running with the starter constantly fighting with the ring gear. I forgot to mention...the flywheel will also rub on the bellhousing - unless you file down part of the bellhousing...or you let the flywheel do that for you which would'nt take long. From what you've said it sounds like the box is in all probablity a TT one then, what made me think otherwise is that the rear subframe is an NA one and from modifications to the wiring on the gearbox looks as if the car was a automatic originally. Thanks for your help matey!
September 24, 200818 yr What about model years?, some came with oil cooling? and i`ve heard that some came with upgraded sync rings?
September 24, 200818 yr What about model years?, some came with oil cooling? and i`ve heard that some came with upgraded sync rings? UK's came with oil cooler, but the boxes are the same, its just that the oil cooler inlets/outlets are not used on the Imports. 1998 onwards had improved syncros
September 25, 200818 yr Does the new type of syncro`s fit the old boxes, or is there any other difference that makes that impossible? Thanks for answers!
Hi,
Cheers,
