Front brakes binding?
Just fixed a crazy shudder which went through car (turned out the sub frame was loose) now got a problem when car run for 20 mins or so. First i hear a sqeaking sound from front brakes then soon i feel a binding/sticking from the front brakes and slight judder through the steering wheel..this doesn't go away once it starts...Any advice gratefully recieved
I had a sticking piston and it did cause a judder under braking.
Does one wheel get a lot hotter than the other?
Jack up the front and turn them by hand to see if one is tighter than the other too.
As Graham has said, sounds like you have a binding brake
Do the above tests, you will definatly feel the difference in temp so watch your fingers.lol
