Wheel advice again
Hey all
I'm trying to get some new wheels and am looking second hand. I have Ksports 8 pots and 350mm front brakes and the 6 pot 330 mm rears. I have found some second hand rims but need to know if they will fit ok? Ive found some 18's on ebay but wanted some advice:
My question is can I run 42 offset fronts and 48 offset rears?
Also can I run 9's front and rear?
Will a 72mm hub be a problem can I sort this with a spacer?
Ron
you can adjust both, use spacers for the offset, spigot rings for the hub.
9" front not a problem, however it's the spoke design that will be an issue for the ksports.
OK guys have bought some 18's 9J all round, any ideas on tyre size that I need to go for? can I run the 9J's with a 235 front and a 255 rear?
That should be fine :)
awesome thanks will probably get some 235 fronts and 265 rears
Thats what i've got bud, and almost everybody else, lol. Can't go wrong :D
