Drumming noise
Hi out there, I have noticed I have developed a sort of drumming or drone type noise. Not speed related as far as I can tell. I have had a lot ow work done underneath, All bushes on each corner, brakes, disks etc. And have tyres only about 200 miles old. Is this a common thing for our Zeds or is there something happening under there I should know about.
That doesn't sound good :(
Sounds like a wheel bearing possibly?
Prop bearing?
Any vibration?
Edited by GUMBALL3000
I had a drumming sound in my car last year. Turned out Cozy Powell was living in my boot.
Helpful as ever :rofl: :rofl:
No no vibration, I will get prop shaft checked out, wheel bearings are fine it appears.
Thank you
must be the donut.
have you uprated diff/subframe bushings? mine are and i get more vibration now :(
I have just had all the bushes done top and bottom at each corner, along with new brakes, discs etc.
yeah but are the diff ones uprated or just standard?
  • 3 weeks later...
Well, it appears that because I left my zed sitting for about 5 months both back tyres have gone a bit out of shape. Not much, but I recon that probably causes that rumbling at the rear. Cause I never had it befor I put the car away. And when they were recently balanced the guy said they were both out of shape a bit. If I drive on them are they likely to get better. (warm up and go back to normal) or not.
Try doing a big fat burnout maybe that'l straighten them out, if it doesnt at least it was fun :D
