No central locking since.............
I had a power failure last week:confused:
Car has been fine since i went over a lot of connections and tightened/cleaned them.
But took the car out tonight and noticed when i walked away from the car,i does not lock.
This is the 1st time i went to lock the car since the problem last week as i have a large integral garage and the car is always in there but never locked.
I have owned the car for 6 years and have NEVER used a key to lock/unlock the car,and because of this they are seized:xxx:
Any thoughts people?
When you are in the car have you tried pushing the lock on the drivers door which in turn should lock both? This will at least tell you if the problem is local or the remote??
vini
Just came back in from mucking about with the,the lever lock on the drivers door is solid.....so might be my problem.
Thanks vinnie for your swift reply may look like i have found prob.
Off to remove door panel:)
Would it be possible that he solinoid has packed up,would this cause the internal door lock handle not to move?
