boost controler
should be coming soon i've ben looking for how to but have'nt found one yet can anyone help
Hi Sparky, If you are looking for aboost controller i have a Blitz DSBC spec S for sale IF thats of any interest to you.
it's just a cheap under the bonnet jobby (like bleed valve)
Just bring it round and look how mine is connected. Just need some tubing, a couple of 2 way connectors and a couple of 3 way connectors. Hare you installing a Boost guage at the same time? What chip are you running or are you going to increase the boost on the std ecu chipset?
Don't know anyone thats risked installing one to be honest!, a boost guage and a chip to up the fueling etc is a must though!!!!
What is it you've bought? as if its just a valve to go into the boost pipe you'll need 2, and have to set them to exactly the same
hi again a turbo thingy (for got in the last five mins)i will look in a min but after hearing it may be a bad ideal i thought about boost jets as i borrowed some 1.2mm mig tips from the workshop i found an installation guide on here and when't to look at the car know i'm clue less on my car the right hand side was as in pics on the guide under the more central intake pipe there was the pipe the pressure line to the wastegate but on the left hand side there was a sort bit of pipe with a bung in it so now i am stumbed is it common to join these pipes eles were and run both wastegate off one side????
sorry i ment to write (hi again i have a aftermarket ecu called turbothingy (for got in the last five mins)i will look in a min
sorry having a blonde day
IIRC the pipe on the passenger side drops down and then goes to the back of your engine lower down, its the one i pointed out to you. I sounds like you have the right one on the drivers side though, they are under the inner of the main intake pipes towards the rad.
the ecu has a sticker on it say programed by turbosystems motorsport
would go and have a look to double check but its gone dark. i know which ones they are on yours its just hard to explain lol
