My problem worsens :(
- Replies 28
- Views 1.4k
- Created
- Last Reply
j1mmytt 11 posts
vijay 3 posts
AndyP 2 posts
Kaza Steve 2 posts
Ok my car is running rich and im getting black smoke when blipping on idle.
today i noticed a nice black damp spray on the ground where my drivers side exhaust is not so much on the passenger side. which means im getting loads of unburnt fuel spraying out.
I just changed the 555 chip to JD one and now it seems to be miss firing on boost
I also get hesitation when blipping throttle which makes it hard to pull away
Ive had it on conzult (thanks Vjay) and lambdas were buggard so ive changed those, everything else seemed ok, running temp etc. tps i think is reading fine.
Ive done a boost leak test and all is fine.
I havent done a fuel pressure test tho.
Would it be worth removing the carbon canister as these can sometimes get blocked although i doubt this has anything to do with my problem.
So what else to check/do?
