hi there can anyone tell me what would be a sensible increase of boost on a stock engine also need it in bar as i'm thick and don't know how to convert PSI into bar
many thanks mark
Well Stock Turbos will max out at 15psi which is pretty much 1bar of boost (1bar is actually 14.5 but you catch my drift)!Condition of the engine will determine it really most people will probably say 0.7-0.8 bar which is still quite a punch! Higher the boost the quicker your turbos will wear out!So if they are old turbos may need to be gental with them! :) Hope this helps although im sure someone will bust my post in half XD
it doesnt sound much but 14.5 psi roughly one bar - standard full boost 9psi or .63 bar
if you tweak it just a little to 12psi or .84 bar probably better due to less chance of detonation
still gives you healthy 30% extra boost .....
Mine reads in hg/mm2? Something like that anyway. What is standard boost in this scale?
1 PSI = 0.07 bar
Stock boost
9 PSI = 0.62 bar
Safty Boost
7 PSI = 0.48 bar
Not sure how this converts into other pressure measurements, google it I guess.
  • 3 months later...
Hi!
I have a Zed (1993) with stock turbos, and it has a greddy profect with a max Boost 14.5PSI....But today in spain people tell me that it have a risk for kill the boost..
He tells me that a max boost for stock boost safe is 0,89 Bar (12.9 PSI).
What do you thing? I need to change the max boost in controller?
Javier
