August 6, 200818 yr hi there can anyone tell me what would be a sensible increase of boost on a stock engine also need it in bar as i'm thick and don't know how to convert PSI into bar many thanks mark
August 7, 200818 yr Well Stock Turbos will max out at 15psi which is pretty much 1bar of boost (1bar is actually 14.5 but you catch my drift)!Condition of the engine will determine it really most people will probably say 0.7-0.8 bar which is still quite a punch! Higher the boost the quicker your turbos will wear out!So if they are old turbos may need to be gental with them! :) Hope this helps although im sure someone will bust my post in half XD
August 7, 200818 yr it doesnt sound much but 14.5 psi roughly one bar - standard full boost 9psi or .63 bar if you tweak it just a little to 12psi or .84 bar probably better due to less chance of detonation still gives you healthy 30% extra boost .....
August 7, 200818 yr Mine reads in hg/mm2? Something like that anyway. What is standard boost in this scale?
many thanks mark
