hard drives
can anyone recomend a good fast HD .
not sure i want to pay loads for a Ratpor drive, but looking for around 150gb
what is the difference between SATA and SATA II
Cache wont make it feel any faster to the average user. SATA1 is 1.5GB/S and SATA2 is 3GB/S. You can pick up an "older" raptor for £90 the new velcoraptor drive are about £120
Yes it's worth moving to a X64 based system if your current architecture is X64
and more expensive and you'll need a controler
yeah, but never mentioned price, just a fast one. i use a 15k one as C drive & got 3 x 10k in pc for storage. i would never go back to any other type now.
Jesus scsi aren't cheep, is there any way i can copy programmes from one drive to another, just i've not got some of the install discs, and wanted to do a frsh install on a new drive
you can copy the whole drive as an image over to a new drive so it instantly works. but if you want to install a fresh copy of windows then you will need the software discs for whatever you want to install. or, if you have the setup program which youve downloaded to your pc, then put it on disc before removing.
WOW I didn't realise they still used SCSI drives!
My mate used to use them years ago, but I've lost touch with him now :(
how do i copy an image over to another drive, do i just select all copy and paste?
no. you can get the software needed from manufacturers websites. what make of drive is the one your using at the moment ?
i have a maxstore and samsung, i think the max is on it's last leggs and i don't trust that make as i've had two go on me in the past. both have about 70gb of data on them and i have a 320gb external drive. the samsung is new ish. the maxstore has all the system on it, how hard is it to copy all the system over to the other drive ie samsung and boot from that one
Thanks for all your help chaps, managed to transfer operating system to the other disk and works fine.Acronis max blast worked well
