Electric Seat jammed forward
Some idiot jammed my passenger electric seat in the forward position when valeting the car - now the forward/backward switch doesnt work (silent when i press "forward" and a little clunk when i press "back") and i can only carry passengers with REALLY short legs now!! For some reason the seat lower/raise control still works fine.
So
!. Is there a simple way to fix this?
2. I presume there isnt a seperate fuse for the raise/lower and forward/back controls.
3. Can I MANUALLY reset the seat where it should be?
4. I have read a thread about reversing the positive/negative lead so I can move the seat but anyone have a step by step for a relative techie novice?
Thanks again guys!!
Can you hear the motor running at all when operating the switch?
dont the motors have a thermal overload cut out switch
Check for coins down the side of the seat jammed in the track.had this a few times.
Coins a good shout, happened to mine:rolleyes:
I've had this in the past with other cars :( Took me forever to work it out the first time :wack: :rant:
Ha ha brilliant guys!! Never thought of that!!
I was having the cooling system pressure tested by a garage today - I mentioned the problem with the seat to them and they have managed to put it back in its normal position but i dont know how they did this. Gentle testing with the switch still reveals it goes forwards but not back.
I am a bit puzzled by this since I assumed there was just one motor and reversing the charge polarity through it made it go forward or back. Once its light I will check the track for coins but if there arent any there does anyone have ay further ideas?
Cheersz guys - love this forum!
You assume correct. The switches aren't very good and the contacts within can get dirty. You can strip and clean them - just be careful of all the small bits inside.
Just realised I didnt answer Vijay's question - no mate I can't hear it when it should be going back.
