head gasket and bore
should head gasket be slightly bigger than the bore size
ie 88mm bore/pistons and rings
88.5 mm head gasket
If your buying cometic gaskets mate, it's thickness they are ordered in.
Headgaskets are slightly bigger than the bore size.
Generally you would go with 1.2mm cometics, if that's what your using and yep would be fine with 88mm pistons. This size piston would require a slight rebore though, whereas the 87.5mm ones would require just a deglaze-hone the bores (slightly cheaper and the extra 0.5mm of piston will gain you nowt)
hth
smithy
hth
smithy
cheers paul
been advised to get bored to 88mm slightly damaged blockl, and a few damaged pistons
Oopps! in that case yep wap the 88's in and if fitting cometic it will be spot on for you, just order the 1.2mm set.
cheers
smithy
dont know what you mean by 1.2 mm
ive ordered 88m
0.51"thickness as they put it at z1 motorsport
ive also just had an e-mail from them stating that they use 1m bigger gasket to piston
so 88mm piston/bore would use 89mm gasket ?
Aye the US use thousand's of an inch, mm is soooo much easier , lol just checked their site and the 0.51" relates to 1.2mm
But yes your right, sorry getting confused they do a cometic now 1mm over bore size, never used to years ago when i first started selling :D
smithy
smithy
right
so what do you think i should do
as i have already ordered an 88mm gasket
should i get it bored to 88mm, or should i just have it honed to 87.5, which would leave me with 0.5mm bigger gasket ?
