Hi,
Does anyone have a link to a write up on the correct way to do a compression test?
Vijay
if you get a low reading, what could be the cause?
A few pointers - there is plenty more to add, and nothing is conclusive without further tests...but gives you some ideas -
150+ is a good strong engine
Getting a bit tired at around 130
A poor dry test, but good wet test would indicate worn rings and/or bore damage. Will often see excess pressure through crankcase such as fumes out of oil filler cap, or pushing dipstick out.
A very low figure or zero compression will usually indicate a holed piston.
No significant difference between wet and dry, but 2 adjacent bores with low figures can indicate head gasket. WOuld need further investigation to prove though - such as Losing water, overheating, gasses in Cooling system..etc
Heads (alloy) can warp
Block (iron) can crack
Once you do a compression test and find a low reading.
Do a cylinder leakage test and find the leak.
Bubbles in the rad = head gasket
hissing from the exhaust = outlet valves
Bubbles from the rocker = piston rings / cracked piston or bore scratch.
Hissing from the intake = inlet valves
Edited by SMW1
added inlet valves
And from the intake? inlet valves?
I sometimes get hissing from my backside.. what would that be then?
IIA valve / idle control valve , they often fail/leak, and result in a poor idle
You have been eating your own cooking :D:nelson:
cylinder leakage test, take it I need a bit of equipment for that??
Vijay
as said - worn ring! :rofl:
haha legrath with the serious post :D
