protoj ·
I dont know if this has been posted before.
If Yes then Ignore
I've been thinking that it would be a good idea to have a 300zx.co.uk calendar with the best Z's or even all the Z's in this forum.
And the money raised from such an action can be given as help to the forum.
What u guys think?
