protoj · Tuesday at 18:48 1 day
I was wondering if anyone on here has tried this ""Dual air intake kit" as found on ebay :)
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=310064552562&_trksid=p2759.l1259
its cheap, does that necessarily mean its nasty? it looks like it does the same job as the more expensive type? maybe the actual filters arnt as good, would there be enouogh space in the zed to replace them with larger filters in the future>?
Many thanks in advance
