Car keeps Dying and EXHAUST needed!!
hi guys/gals,
Need a bit of advice on this one. Ive got an Auto, H reg, N/A 300zx.
When im stopped at a junction, lights, roundabout etc. I put my foot down and the car seems like its stalling then picks up again.
It has now also stalled a couple of time and i have to put it in park then turn the ignition again, this only happens every now and then but always at the worst times!
My exhaust is blowing and ive found that there are small holes before both of the cats, not too sure if this has anything to do with this problem?
I also have my MOT coming up and know that my car ISN'T going to pass with the exhaust like it is, does anyone know where i can get an aftermarket exhaust system that will solve this??
Please can anyone help!
  • Replies 30
  • Views 1k
lol. its the iaac one, when you remove the motor, does it just pull out the same way as the motor???? cant seem to shift mine
yes it should just come out. spray carb cleaner in it and a gentle tap from your hand should start to move it.
Your stopping problem sounds like your gearbox is knacked. I'm sure someone on here can tell you why, but it's happened on my last two gearboxes, a few months before gears started disappearing. After replacing the box it is fine again.
Get your gearbox oil changed, see if any little bits of metal fall out?
Mr Pink
oh great!!!! More probs, i bloody hope its not bcos that isnt cheap i know that much! Cheers for the heads up though think ill be checking the oil on my next day off now!
hellraiser: I might be at yours around 8 saturday, ive e-mailed you just to let you know too.
