protoj · 16 hours ago 16 hr
Hi,
after a lot of research on here and other sites and as a preliminary diagnosis, i reckon the main centre prop shaft bearing needs replacing. What would the total cost of replacing the bearing plus labour come to? I'll source the bearing myself say for £150 so how many hours labour etc?
Adam
