the dreaded blue smoke!!
Hi people
I have posted this problem a while back, but just want to be sure of the problem.
While coming on the gas, then coming off, above 3000rpm, no problem.
Below 3000rpm, i give it some gas then foot off for approx 2-5 secs, then the blue smoke starts to roll out, foot back on the gas, ooohhh my god!!! loads of the blue stuff, then its clear. As i said before, higher than 3000rpm, no smoke.
It's a TT, jap, 555 injectors, hks induction, hybrid tubs, de-cat, manual, boosting at 15psi.
Any ideas?
Cheers,
Alan
  • Replies 34
  • Views 1.3k
I had a spare engine, which was chucked in.
One i did notice though that when driving my car and said smoke was billowing out of the back, if you put the clutch down it stopped. I had a whole new driving style because of my car and this LOL. Smoke was only on De-Acceleration
Check for any smoke from the dipstick and oil cap with engine running. Did you do a wet test on the two 130 cylinders ? , just a few drops of oil to see if it rises.
just done a wet test on the 2 low cylinders, both came back at 138. originally were 132.
does this confrim anything?
cheers
alan
Id say it indicates your piston rings are loosing pressure.
if i go down the road of replacing my pistons and rings with wiseco forged ones, what other bits will i need to complete this job?
also, do i need to pull the engine out for this?
cheers
alan
Its a lot easier to pull the engine (i think i recall i can be done it situ, but everybody pulls the engine) and whilst it is out go around and replace all the vac hoses, plus do a plenum water and egr bypass.
if i replace the pistons and rings, do i need any thing else? is it worth getting a complete gasket set or just the ones i need?
cheers people
alan
cheers people
alan
Mate if you replace the pistons and rings your obviously have to fit new bearings and for the price of a set of complete engine gaskets then id say yes do them all, you can buy a kit with all the gaskets you need including valve stems, hg's, plenum gaskets, throttle body gaskets etc etc.
If your pulling the engine,do a rebuild!-saves a lot of hassle later!;)
hey mantav
whats the price difference with just piston and rings, compared to complete rebuild.
dont want to spend tooooo much money that i have not got, lol.
cheers
alan
