bulb holder
hi people
does anyone have 1 of these little puppies????
or, does anyone know where i can get 1 from???
nissan dealer say 28 day lead time!!! am going to the nurburgring next weekend and want to fill the little space in the front indicators (even if they do not work)
cheers,
alan.
You should be able to fit 501 bulb holders in there. Those are the same as in the side repeaters so check the breakers on here for some. This is also a common part among a lot of other cars (not just Nissan) so if you have a local scrappy you may find some there. Alternatively, stick some aluminium foil on the back of the aperture - you won't notice there's a gap then ;)
Regards,
Dan
Edit - just reread you post - I take it you're refering to the actual indicator in the front bumper and not the little hole that sits directly behind the indicators. If that is indeed what you're talking about then look for 581 or 382 bulb holders (again - check with breakers on here first). Sorry for the confusion but the 501's are for the aperture behind the main indicator bulbs ...
EDIT No. 2: The picture you've just put up is for a 501 capless bulb (also known as a W5W bulb). Forget whatever I said above ...
wish you'd said last week i've just cleared the garage out and i'm sure i saw a couple of them
