protoj · Tuesday at 18:48 1 day
my 300 is occasionally losing power when i'm on the go.it's not at any particular speed but when it happens the exhaust tone changes and the car doesnt pull as much.if i drop a gear and take in to about 5 and half on the revs it seems to clear.any suggestions as to what this could be?thanks, Dave
