boost guage fitting
Is there a how to on this forum for fitting a boost guage. i cannot find one but then i never can in the search???
Or can some one advise which pipe to T into
Just T into one of the pipes that comes off the balance bar. Easy peasy mate :) Hardest part is getting it into the cabin from there :rofl: :wack:
Any off the 2?? as i want to get rid off the AIV aswell
t-piece it from the pipe that sits on the driver side
There should be one with a T or Y already in it for the stock gauge on the drivers side. I just plumped into that.
You can go through the firewall via the bonnet release if you don't fancy drilling or making any more holes. The hole should be have a grommet whihc you may just need to slit a little wider. I've run a boost gauge wires and boost controller through there without any problems.
