Stainless strip on throttle cover?
Anyone know what i can stick this down with? Mine keeps on lifting. I did make sure it was all clean etc before i stuck it on.
Assuming the old strip is removed, a few dabs of strong super glue under the tip where it's lifting.
When fitting from new and old strip is removed, place the new strip ontop of the cover and you'll see the cover is curved, with the new strip in your fingers, make a slight curve/bend to match, ( where the 3 is i think) place the strip back on the cover and it should all sit flat now. If it does then peal the backing off and apply, keeping pressure for a minute or 2.
hth
Smithy
Thanks for that mate. Would the super glue not react with the double sided tape?
It should be fine bud ;) :)
Cheers, just dont want to make a mess of it as it lloks good apart from the ends lifting!
