Help with Profer B 2 settings again/still
I'm still having trouble dialing mine in :headswivel:
I'm aimg for 14.5PSI which I think is the norm. I'v set it up and I'm getting 14.5 +/- .2 PSI on Max boost when floored but it then gradually tails off to around 11 - 12 PSI and I can't for the life of me, whatever I adjust, stop it from tailing off. What should I be adjusting +/- to prevent this ?
CheerZ
Paul
Try turning the start boost down a bit, as your wastegates might be opening too early.
CheerZ
Paul
Sure you dont have any boost leaks stopping it holding a decent pressure??
