Hey all, I've finally got to the root of my problem, piton rings blown and the piston is shot to shit. This has caused a very slight groove in the cylinder. Now, I'm taking it to a place on friday, having the cylinder re-bored, probably will only need about 0.0020" taking out, but this will require an over sized piston. If I only change the one, and make sure the new piston is exactly the same weight as a standard piston, can I get away without replacing all the other pistons? Surely the fractionally greater compression on that cynlinder wont make any difference, will it? Obviously all pots re-bored and a full set of over-sized pistons ain't cheap, so would like to get around doing that if possible!
Any advice would be greatly appreciated, cheers you lot! :-)
