Me again.
So I have two questions:
RobHowl ·
Hi need some help here my friends./
I´m in the process of changing rear tires and front,
I want to fit a 275/35/17..on back...and 245/40/17 on front,
only problem is I am going insane and crazy since no one seems to have these measures on 17reem...looked on yokohama and all mayor brands,
please does anyone knows a place either in the states or mainland where I can order and they have them??
would be so greatful! really appreciated guys
thanks:cry:
