protoj ·
black with white markings by day but lights up like the usual el dials do?
Sure I saw them somewhere but can't find it now.
Also seeing as I have a 95tt would it work getting the n/a ones i.e. without boost gauge seeing as i don't have one as standard?
ta
jay
