Balance bar off to change plugs??
Yep :)
Its a zed of course it does hahahaha
remember to tighten it back on correctly or you will crack the plenum.
Yeah it does! And some people don't! As i found out when i had my last service done and my mech found that the back 2 had not been changed as often as the front 4! :rant:
What do you mean ? Are there torque settings for the bolts??
Also are they just normal rubber o rings?
Yes torque settings. Dont just tighten them or youl risk cracking the thread part, easily done i recon.
you can just refit the O rings but they are often brittle and could do with replacing !
just dont overtighten the bolts and nuts !
If your O rings are good, you can just run a little red (semi hardening gasket in a tube)round the edges to make sure you have a good seal.
Cool, going to sand blast and paint the windsreen wipers / window trims so might blast and polish the balance bar whilst i'm there :D
