ive just fitted a heads to my tt as it had bent valves
i replace it with a head for a mates car using my cams and lifters
so away i did a compresson test and only had 30psi did it again and got it up tp 60psi what going on all of the ofter side have 150psi
dose all the oil pipes from that side have anythung to do with
Did you make sure both mating surfaces were clean and smooth? Also what head gasket did you use? Was the doner head pressure tested before fitting?
Could be that the lifters are slightly jacked out and need time to settle...
