Ii there a fuse for the Cental locking
As above or is it more likely that the unit under the O/S door card has failed?
Or that the alarm is up the spout and causing the central locking not to work.
All was Ok before it went in to the to body shop. They Claim they haven't touch anything and I cannot see anything. The Battery has been off for 7 months?
Does the passenger door lock when you lock the drivers door with the key - if yes then central locking ok and you need to look at the alarm. Could be alarm itself or the aftermarket solenoid fitted to the drivers door.
If just the drivers door locks with the key and the passenger does nothing then it could be either the fuse in footwell fusebox, or solenoid in pass door, or actuator switch located in drivers door underneath locking mech.
