Are O2 sensors the same for turbo and NA models?
Subject says it all really. I can get the NA sensors no problem, TT is not listed with my supplier. Another reference I've seen (ngk.com.au) lists the same sensor for all models and, presumably, for both sides (unless their partsearch only shows the first entry in their database).
Advice appreciated.
RobH
Hi Rob
All sensors identical according to Smithy (i think it was) except for US/ Canada - which I assume is for emissions regs or similar...
Rich
Hi Rich, did you get my email last night??
Ok the prob is that I was going to import sensors from the US. I can't see why the sensor would be any different though - it's what the ECU does with the signal that's important surely? Possibly different due to lower RON fuel?? Any ideas - anyone?
H
Oh, and the other odd thing is that one side O2 sensor is considerably more expensive than the other - can't see any reason for this, I think someone mentioned that the wires were longer on one side...
Yup one often is more expensive than the other if bought seperately and the difference in sensors is from sept 93, these i think are slightly dearer than the pre 93 ones.
smithy
